Vibration in left bag and pipe.
Old 02-25-2011, 04:09 PM
nhbiker1961's Avatar
nhbiker1961
nhbiker1961 is offline
Another thing that may be happening,, if you touch the slip on muffler at the very end and the sound goes away, then there is a rubber bushing on the exhaust that absorbs the vibration. I had to wedge a small piece of rubber (cut from an inner tube) in mine to tighten up this so it didn't rattle. If you remove the bag, you will see this rubber bushing where the pipe is bolted to the bar.
Old 02-25-2011, 04:31 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
also make sure the rear muffler hanger is somewhat centered if the pipe slips back it will hit on the hanger. also look for heatsheild clamps make sure they dont hit anything when its running.
Old 02-25-2011, 05:11 PM
tidbit1's Avatar
tidbit1
tidbit1 is offline
Gonna check everything on that side tomorrow am.
Thanks . Don't you love this site....
Old 02-25-2011, 06:28 PM
bigdumbnoitall00
ive been through all this , to finnaly figure out i got a bad headpipe from the factory.if i dropp both rear hangers my right side pipe stays tight to the bag rail the left side will dropp to the floor tryed readjusting headpipe to no avail,looks like the 2-1 ive been eyeing is coming sooner than later.
Old 02-25-2011, 10:20 PM
103 sedona orange's Avatar
103 sedona orange
103 sedona orange is offline
there is another part called a Muffler Mount & is also rubber. It under the bags, but your nuffler should be vibrating more also. I would suggest you take both bags off & check all bolts,the rubber type grommets that the pins go through to hold the bags on. you need to think back when it started. good luck & get back & let us know what you found
Old 02-25-2011, 10:43 PM
mfuchs2004's Avatar
mfuchs2004
mfuchs2004 is offline
Only seen it once, but can't hurt to check:
Might have dropped a washer on one of the bag attachments (the half-twist pins). I test drove a bike that was missing a washer and it shook like heck.
Old 02-26-2011, 04:53 AM
katobird's Avatar
katobird
katobird is offline
Had the same problem when I installed the true duals..
But the above posts covered it pretty well
Bags on the rails, muff support.
Mine was rubber muff support not centered
polbit
2018+ Softail Models
14
03-07-2019 08:12 AM
Spokane2303
09-01-2018 05:28 PM
mrm_flhr_14
04-08-2015 11:07 PM
Mountain Cruiser
2014-2023 Touring Models
16
05-18-2014 09:02 AM
Bama Harley
09-21-2006 04:08 PM
Quick Reply: Vibration in left bag and pipe.
