cam chain tensioner
Old 02-24-2011 | 01:59 PM
Keitht's Avatar
Keitht
Default cam chain tensioner
My 08 UltraGlide has 15000 miles on it. I'm reading lots of post about problems with cam chain tensioners. I am not a mechanic. I put the bike in the shop every 5000 mile for a check-over. Is this something I need to be worried about? Like I need something else!
Old 02-24-2011 | 02:06 PM
soos's Avatar
soos
You should not have any problems. Your scoot has the newer upgraded hydraulic version of cam tensioners. The problems you are reading about concern the old style spring loaded tensioners used before '07.
Old 02-24-2011 | 02:15 PM
my67pnycar's Avatar
my67pnycar
15000 miles plus you take good care of it, you should have plenty of miles left.
Old 02-24-2011 | 03:04 PM
Keitht's Avatar
Keitht
Thanks guys.
Old 02-24-2011 | 04:48 PM
dgretz's Avatar
dgretz
Had mine done on my T-sport under the ESP, dealer was even able to get the adjustable push rods installed as would have had the same amt of time or more into cutting and installing the non-adjustable ones to do the tensioner install.
Old 02-24-2011 | 05:13 PM
jjpish's Avatar
jjpish
My 2003 RKC is in the shop as we speak having them replaced for the first time at 53,000 miles...I think you have a few more miles ahead of you
Old 02-24-2011 | 05:17 PM
vet767's Avatar
vet767
I have talked to several techs at local hd shops and they say they are seeing 80000 miles with no "appreciable wear" with the new hydraulic system in the tc96. Not so with the older system in the 88
Old 02-24-2011 | 05:35 PM
D.Chavez's Avatar
D.Chavez
6th Gear
I was at a local bike shop that does work on mostly Harleys. He scared the hell out of me telling me I should not be riding my 07 FLHTC (41,500 mi.) because I am rolling the dice with the cam chain tensioners. He pointed out three bikes that were in his shop due to the fact the tensioners gave out and the motors were blown. He recommended I change to the gear style. I don't have the money(he stated $2,150) to go to gears. Riding weather is almost here I don't want to trash the motor by riding it, is there anything else I can do at a more reasonable price? Can I check the wear on the tensioners myself, seems everyone just wants to make money off you after you buy your bike. Any help appreciated.
Old 02-24-2011 | 05:48 PM
vet767's Avatar
vet767
For those like, mr. chavez that are concerned here is a link pretty much shows what to look for and at. Mr. c, gonna bet they just want to sell you the gears and the labor
http://www.harley-davidson-hangout.c...ner-check.html
Remember these are on an 88 with the spring tensioners not the new hydraulic like the 96 and later
Old 02-24-2011 | 06:03 PM
MNPGRider's Avatar
MNPGRider
Go back and tell your tech that you have an '07, and ask if if he knows the difference between spring loaded and hydraulic tensioners. There have been reports of early failures of the new system, but they apparently are few and far between.
BTW, my conversion to gear drives was a total of $1008, including labor at a Harley dealer.
Yes, you can check them yourself. They are still made out of plastic, which is subject to heat stress down in the cam chest. Get a dental mirror. I would check them as often as I would check the primary chain tensioner.
Quick Reply: cam chain tensioner
