'02 Roadking only fires on front cylinder
Have you actually checked for spark at the plug, or are you just going by the fact that the rear cylinder isn't working? In other words, did you pull the plug and ground it to the motor looking for spark? Or stick your finger in the wire and spin the motor over.... If not, do so. If you have spark, run a compression check.
same issue
my buddy is having the same issue 04 electra glide He removed the front plug bike was still runing but no spark he licked his finger and stuck it in the spark plug wire no buzz, put back on front plug then took rear off and bike died . then put back rear spark plug back on bike, started bike then pulled rear plug again bike ran fine. is the coil bad or igniation or wire.
i am having the same p[roblem except if i ride the bike about a half mile the rear cyclinder fires and then the bike runs ok
also looking for help
nickolas.noga@gmail.com
Mickeys Customs
10-26-2007 07:35 PM
