before i order, will these fit?
If I remember correctly the EIII is rated about 50 or so more pounds than the 402. You can go to the Dunlop site and they have it listed.
SIZE LOAD/ SPEED INDEX SIDEWALL PART # APPLICABLE RIMS
RECOMMENDED RIM OVERALL DIAMETER OVERALL WIDTH FULL TREAD DEPTH MAXIMUM LOAD @ PSI
Elite 3 Touring Front
MT90B16 72H BW 4079-90 3.00 25.00 5.24 6/32 770 @ 40
150/80-16 71H BW 4079-89 3.50 25.54 5.97 6/32 761 @ 41
MR90-18 71H BW 4079-84 2.50 26.40 4.70 6/32 760 @ 40
130/70-18 63H BW 4079-78 3.00 25.15 5.00 6/32 600 @ 41
MM90-19 61H BW 4079-73 2.15 26.41 4.04 6/32 570 @ 40
90/90-21 54H BW 4079-21 2.15 27.10 3.54 6/32 467 @ 41
Elite 3 Touring Rear
MV85B15 77H BW 4079-45 3.50 25.50 6.02 11/32 910 @ 40
MT90B16 74H BW 4079-91 3.00 25.70 5.15 10/32 830 @ 40
MU90B16 78H BW 4079-95 3.00 25.72 5.57 11/32 930 @ 40
160/80B16 80H BW 4079-96 3.50 26.10 6.10 11/32 992 @ 40
I would go with the MU90 for the rear
Definitely get the MU on the rear. Not only higher load rating, but also wider.
Here's the chart to compare all of them:
http://www.dunlopmotorcycle.com/tire...tire.asp?id=86
-Dusty
You're right!! With my '03 I tried the MU and and it rubbed on the belt. Dammit!!!!!! I just bought a Metzler MT90B16 and I hope it fits....the '03's are a bit different, very little room!!!
