FM 107 kit completed
I wouldn't think the Thunderheader would hurt you. I'm betting it's in the dyno machine. Our best local tuner uses the dynostar like Ed's and his numbers seem to be higher than another guy that uses the dynojet 250i. I prefer the printout that the dynostar gives because it shows the AFR of both cylinders (two separate lines) and shows the TQ and HP at several different percentage throttle positions instead of just wide open like the dynojet does. Very nice build you've got their and nothing to be ashamed of by any means. The FM kit looks to be a lot of muscle for the money. Congratulations!
FM 107 Kit - 1300
SE Heavy Breather - 300
Headers/Exhaust - 700
Dyno Tune - 525 (225 DirectLink License plus 300 for the tune)
Clutch Plate/Spring - This was done by Harley since I was there for my free 1000 mile maintenance. was 375. probably could have done it myself for half that.
Misc: Oil/Lube/Gaskets/Tools - Around $200
Optional - SE Easy Install Pushrods with covers - 165
I borrowed bearing puller and press from the LBS.
I would have been interested to see what the deck height was on this motor. We have not built any of them that have had this high of cranking pressure, they are usually in the 190 range.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
