Big Bore Project Part Three
Old 06-12-2011 | 10:04 PM
speakerfritz's Avatar
speakerfritz
congrats...super DIY job. so you fired it up and took it for a spin. awesome
  #42
Old 06-13-2011 | 09:21 AM
atrain68's Avatar
atrain68
Originally Posted by thegoschman
Excellent Posting!
First time Harley owner and I'm going through the same with my 04 Night Train.
You said that the heads were powder coated. The actual intake/exhaust ports had this in them??? I wondered because the intake on mine had areas of black and areas of bare metal. I thought that this was from back firing or something.
What was your secret to removing the old gasket material from the heads?
It looked like powder coating, but I might be wrong. For gasket removal, I carefully used a straight edge razor to remove any residual gasket. I took my time and used care not to damage the metal surfaces.
  #43
Old 06-13-2011 | 09:03 PM
thegoschman's Avatar
thegoschman
4th Gear
Thanks for the reply. I'll get a bucket of elbow grease and get crackin' on the old gaskets.
I worked out a nifty way to install the 2nd circlip without paying a bazillion dollars for the tool.
A short (2") copper 3/4" tube and a deep 5/8" socket. Press the clip into the tube just past the clips halfway point with the ends of the clip pointing up. Rotate the clip so the ends are touching the rim of the tube. Insert the socket into the other end of the tube. Press the tube firmly against the piston and smack the socket with your free hand. Harley pistons work easy. S&S pistons required me to hold the tube with a pair of channel lock pliers so I could put more pressure against the piston. Beats spending 130$
  #44
Old 05-13-2012 | 09:34 AM
cruzmisl's Avatar
cruzmisl
I know this is an old thread but had to say thanks for the great write up. I've done tutorials before. Taking pictures during the build and writing the article takes a lot more time and effort than most people realize.
MURPHCC1
Engine Mechanical Topics
12-03-2017 07:45 PM
CRZYLGZZ
06-08-2015 03:25 PM
batch
EVO
26
12-09-2012 11:58 PM
atrain68
02-10-2012 10:07 AM
SE7EN
Exhaust System Topics
13
02-01-2010 12:20 PM
