V&H Pro Pipes Discolored
Spent a week in Florida. 850 miles. Pipes are purple and splotchy and at some places all the finish came off and it rusted. Working on getting them warrantied. I had the dealer install the pipes, A/C, and tuner before I picked up the bike.
I was told it may be a sign of running lean but the discoloration is the entire length of the pipes not just at the heads. The bike only backfired a couple times at decel, it did sound "flat" a couple times after coming off the highway and hitting town traffic but I could have been imagining it, and the heat off the engine never "felt" abnormal or uncomfortable to the point that I was concerned. Started without issues even when hot.
That sucks! Have you looked at your plugs for a lean condition? Decel pop can be a sign of an exhaust leak, not saying this is your reason. Did the dealer do a dyno? The discoloration and rusting obviously is not a sign of a lean condition. Whatever coating that was put on the pipes, it wasn't done right. Hope they square it with you.
Only popped a couple times on decel and I think that is because I loaded it up. Haven't checked the plugs. Not a believer in dyno for a mostly stock street bike; if they tuned it properly with the SE tuner it should be ok. I don't want to mess with tuner settings until I talk to the dealer.
Chip
Chip
