cam recommendations
Old 02-21-2011, 05:53 PM
remmag's Avatar
remmag
remmag is offline
Default cam recommendations
hey everyone
i have an 03 roadking with 30k miles on it, i am going to have the cam chain tensioners replaced to be safe and thought while this was done i would change the cams, i want a cam set that will give me more power starting out with 2 up, but dont want anything radical
any recommendations would be appreciated
thanks
Old 02-21-2011, 05:57 PM
jackinthebox's Avatar
jackinthebox
jackinthebox is offline
Hq-34, Andrews 21,26 are bolt in cams
Old 02-21-2011, 06:51 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
+1 on the Head-Quarters HQ-0034. I've had them for several years and haven't thought about a 95" build since. Andrews 21 and 26 are popular, as is the S&S 510.
Tons of cam threads here; just use the search function and you'll have days of reading.
Good luck with your research.
Carl
PS: Go to Bigboyz' website and use their cam comparator that allows you to compare the cam specs of 3 cams at once. Generally, the earlier the intake valve closes, the earlier in the rpm's the torgue increases.
Old 02-22-2011, 07:52 AM
04 rkcrr's Avatar
04 rkcrr
04 rkcrr is offline
Just put a set of HQ-0034 in my 04 flhrs and I am extremely happy. I was considering a 95" or 98" But didn't want to spend the money. By far the best mod I have ever done, My only regret is I didn't sooner. Once again I'm extremely happy with this cam.
Old 02-24-2011, 09:35 AM
parakiller's Avatar
parakiller
parakiller is offline
What bolt on cam would you recommend for an 07 road king 96"?
Old 02-24-2011, 10:11 AM
equandt's Avatar
equandt
equandt is offline
Check out the Woods TW-555 or TW6-6. They seem to be pretty popular right now.
Old 02-24-2011, 10:15 AM
iclick's Avatar
iclick
iclick is offline
Where do you want the power to be realized? Low-end, midrange, high-end?
Old 02-24-2011, 10:42 AM
fripple's Avatar
fripple
fripple is offline
Depends on the riding style...
SE-255, SE-204, Woods TW6-6, TW-555 and on and on...
Old 02-24-2011, 11:26 AM
2D3K1H1B1HIM's Avatar
2D3K1H1B1HIM
2D3K1H1B1HIM is offline
I'm in the same boat been lookin at doing the s&s 97" kit I have and changing my HQ 0034 cams out to something different...a little head work and comp increase....just cant get past the 2 grand it will cost,wish I had a bigger crank(DON'T WE ALL) then I'd do a 107"
Old 02-24-2011, 04:01 PM
parakiller's Avatar
parakiller
looking for touring...more power going down the highway...I ride long distance and usually am pretty loaded (weight wise).
Quick Reply: cam recommendations
