Maybe Got Some Bad Gas.
Bike has been running fine for the last 20-30k but recently has started runnin' rough at low speed around town. Get out on the interstate and it runs smooth as silk. It all started after I got some gas at a new Racetrack maybe not right away but by the next tank for sure. I'm going to replace the fuel filter how hard is this? The manual says I have to drain the tank to relieve pressure. Is this necessary, has anyone else done this.
Thanks in advance.
Thanks in advance.
I got some water in my tank when I filled up at one of those stations. I put in 4 gallons-2 gal gas, 2 gal water. Bike quit running. Had to drain and pull tank then clean out. I changed the fuel filter and put a half can of seafoam and filled up with good gas. Turned over for a while before it started. It spit and coughed for about 15 seconds then smoothed out and has run like a top for the last 35000 miles.
I used a brass rod and hammer to loosen the top part and reinstall it.
Cecil
if you have trouble with water in your gas, a bit of "HEET" which is an alcohol based additive that homogenizes that water to the gas, allowing it to burn off. this is what theakerr mentioned. keeping a small bottle of heet in your saddlebag shouldn't hurt anything, or you're always near a walmart where they sell it.
As a matter of fact, it is. Try not to get gas there, but sometimes have to unless I want to go about 15 miles out of my way (which when I am going to work, an hour+ ride anyway, isn't much of an option).
Does not sound like the filter if it runs good on the hwy.
Heres a link for changing the filter .........
http://www.hdforums.com/forum/tourin...to-w-pics.html
