Why not the balanced motor?
It has to do with the way it is mounted. Unbalanced is rubber mounted, balanced is solid mount.
The cams and crank are different also. balanced has chain on the crank for the counter balance. As for the cams the harley tech said that the bearing is smaller thats why I couldnt buy a 251 cam for my dyna.
You know, I never ride real fast, but I've been fairy fast on the 96B, and let me tell you, though I've heard it 1,000 times, there is no vibration at speed at all, no low vibration, no high RPM buzzing, nothing. Maybe it's the 6 speed, or maybe it's that I don't ride at 120 mph...
SG is just the opposite. Vibrates at idle and is smooth as glass at all other speeds.
Dennis
Ride for 8 hours on a solid frame mounted 96b, and then do the same on the isolated rubber mounted engine on an HD touring bike and you will have your answer.
