Air cleaner performance choice
Old 02-19-2011 | 03:04 PM
vmax94's Avatar
vmax94
SE Heavy Breather is a very nice clean looking unit.
Old 02-19-2011 | 04:52 PM
HotRoc54's Avatar
HotRoc54
I just removed my SE Heavy Breather and installed a SE Ventilator.
After installing the Lindby bar I could not get my right leg around that Heavy Breather to have my foot rest properly on it. Just my
Old 02-19-2011 | 05:26 PM
big6x6's Avatar
big6x6
I have a SE Heavy Breather on my 2010 Street Glide... I like it and it looks GREAT on a Steet Glide!...It DOES get in the way of your right leg a little and it takes some getting used to... The HB may in fact have a slight advantage at speed but certainly not on the stationary Dyno...
Old 02-19-2011 | 08:03 PM
ElectraEd's Avatar
ElectraEd
I've got a Zippers Maxflow Air Cleaner mounted to an HD Stage 1 backing plate with an Arlen Ness Smooth Chrome cover.
Attached Thumbnails Air cleaner performance choice-zip1.jpg   Air cleaner performance choice-zip2.jpg   Air cleaner performance choice-zip3.jpg   Air cleaner performance choice-zip4.jpg
Old 02-20-2011 | 11:10 AM
ucommbxny's Avatar
ucommbxny
i just removed a compact heavy breather part # 28716-10, it is for sale $190.00 shipped USA only. you will have to buy new gaskets since it is a take off. if interested send a pm
Old 02-20-2011 | 11:30 AM
Cornhusker's Avatar
Cornhusker
The last few years, I've run a Ness BS naked. Installed the Ventilator on this ride and seat of the pants, it seems to do fine and plenty of clearance for the leg.
Old 02-20-2011 | 11:32 AM
RidemyEVO's Avatar
RidemyEVO
Is there any problems with riding in the rain?
Old 02-20-2011 | 12:32 PM
MNPGRider's Avatar
MNPGRider
If you carefully study the before and after dyno tests on air cleaner upgrades, you will discover most give no increase in performance in the "riding rpm" range, and some even decrease. The most current example is in the newest (April) issue of Amercan Iron, page 118. There is no significant increase in either torque or hp until after 3250 rpm.
For a major exception to this, do a little research on http://www.dohertymachine.com/
American Iron tested Doherty's system in May of 2003 and again back in June 2010. They point out in both articles (dyno charts in articles) that power (and torque) is increased for the entire rpm range, not just at high rpm.
If you're running Harley air cleaners, for a cheap upgrade don't overlook the Boyeson X-Wing that fits in behind the stock backing plates for instant increase down low in the rpm range. Tested in American Iron Dec '08. I installed one a couple of years ago in my Screaming Eagle air cleaner and immediately noticed how instant the throttle response was.
Old 02-20-2011 | 01:23 PM
supermoto292's Avatar
supermoto292
Staying with stage one and stock cover, because it does not get in your way.
Old 02-20-2011 | 04:42 PM
ElectraEd's Avatar
ElectraEd
No, This is the second Ultra I have run it open like this and have never had a problem in the rain. I have ran thru a few downpours.
