King Tour Pak backrest pad
Received 49,926 Likes
dawg is correct. here's a sample pdf to show what's in the kit (including template).
http://www.harley-davidson.com/en_US...ts/-J00536.pdf
Not sure but maybe this will help.
https://www.hdforums.com/forum/attac...backrest-2.jpg
Another member has a template for the OP. There is another thread with the same title with the info. Drilling the holes in mine (fiberglass) was easy. The ABS should be easy as well, just don't push on the bit, let it do the work.
Good luck Kdodd, when you see the next guy looking for a template, you send it on to him.
https://www.hdforums.com/forum/touri...ml#post7937993
Thats what I was told as well. Then I was lucky enough to contact someone at a dealer willing to put a little effort into the situation. There are folks that only do the minimum to get by and others who will put out a little effort to try to help.
There aren't many willing to go the extra mile any longer.
Template
So do you have one? are you able to copy it and pass it on? If so, you would be a life saver. Let me know, kdodd47@gmail.com
You've got two threads going with the same title. See the other one for the details.
https://www.hdforums.com/forum/touri...krest-pad.html
