Heavy Breather vs. Lowers
Old 02-18-2011 | 08:30 PM
pretz's Avatar
pretz
Default Heavy Breather vs. Lowers
If I install lowers on my SG will the Heavy Breather be restricted and should I go back to the stock air filter?
Old 02-18-2011 | 08:34 PM
qtrracer's Avatar
qtrracer
There is a guy in the Touring parts in the classified section looking to trade his compact filter for the HB (to fit with lowers) for the full size filter, Colin and then some number is his screen name.
Old 02-18-2011 | 08:48 PM
mkguitar's Avatar
mkguitar
if you do have a problem you can get the chrome backed Ness Big Sucker for $115 shipped on ebay from easternpc.
the chrome back is easy to wipe clean when washing the bike, works with the stock cover ( which does a nice job hiding the wiring to the throttle body )
that way you get the hi flow breather and a washable oiled filter
mike
Old 02-18-2011 | 08:56 PM
pretz's Avatar
pretz
I guess I should have said that I already have the Heavy Breather installed and was thinking about purchasing lowers.
Old 02-18-2011 | 09:01 PM
ybnorml's Avatar
ybnorml
You should be alright unless you want to add the vents and or
glove boxes....if you want those then I think you will need
the compact breather.
Not positive on this.....hopefully somebody will chime in that
has the set-up.
Old 02-18-2011 | 09:04 PM
kjkustoms's Avatar
kjkustoms
If you do install lowers there is a shorter elbow available, even with this elbow, the glove box to filter distance is about 1", the glove box will be useless you will not be able to open the door, ask me how I know!
Old 02-18-2011 | 09:07 PM
qtrracer's Avatar
qtrracer
Default HB standard vs HB compact
Only the filter is different, its a compact filter. Not too complicated.
Old 02-18-2011 | 09:42 PM
D2R's Avatar
D2R
You have to have the short filter,the intakes are one in the same.Aprox 1/2" between the filter and lower so speakers etc. are probably out of the question.No restiction on air flow.No problem getting into the glove box.
plutnicki
Milwaukee Eight (M8)
03-30-2019 01:15 AM
yank721
Audio Systems
05-03-2016 03:10 PM
UltraNutZ
08-01-2013 05:44 PM
airbike
01-18-2011 12:43 AM
jm1211
02-19-2010 08:57 AM
