High TQ. clutch setup
There is a few threads on different forums on the SE compensator/atf issue. I ran the Redline MTL primary and saw what started happening with my SE compensator,the mtl looks very much like atf and is very thin. Testing that people are doing shows that the bore and spokes of the SE compensator requires or like a much heavier oil to not start the fretting in the sprocket bore or galling of the spokes. Check out the SE compensator thread on htt Rabos explains it and there is pictures. All i can say is you use hypoid gear oil in your differential on a car or truck not atf and if you did fill it with atf it might not last too long.
1 Post
I bought part# 630-346
from j&p
http://www.jpcycles.com/catalog/2010...?entrypage=570
We'll see how the 120R handles things.
I was talking to the tech yesterday, he said no issues with the Rivera. He never used the gold springs, just the silver ones.
I bought the gold springs anyhow. Left hand might need a workout... I've got the squeeze handle thing in the work truck.
You'd think HD would have this sorted...
H
H
Gold clutch spring
I'm a little worried from what you guys have posted, I bought the proclutch with the tpp for the stock clutch basket, do I need to get the gold spring seperate. Yikes more mods more $$, the stock clutch basket should be ok under 120 torque right?
from j&p
from j&p
Barnett Scorpion
I looked at those and they seemed fine but they use the coil springs vs. diaphragm and i'm not happy with the pull of my SE race clutch with coil springs. Plus if you want to add the lockup pressure plate to the Barnett you need their primary cover so i started losing interest quickly with them. I know that i made the wrong choice with the SE race clutch and would like to get it right this time.
1 Post
HFS
07-21-2015 10:36 AM
