Tomorow I plan to install a HD oil cooler on my 09 Ultra. Looks pretty straight forward but I wanted to check in with you all to see if there is anything to watch out for or tips or tools I might need
Thanks
Keith
Thanks
Keith
There is a large size allen that I had to get. I can't remember its been so long. I am sure someone will chime in. Make sure you get the gasket on right so nothing gets blocked.
Thanks
Keith
Tips:
1) If you have a chrome rectifier cover it won't fit back on with the cooler.
2)As the others said...make sure you have the Allen wrench before doing the job.
3)Make sure and use RTV sealant when putting on the gasket (Mine leaked the first time.
4) Make sure to get the oil draining plastic funnel from HD for draining the oil from the filter, you will now need it.
5) Leave the screws for the hose clamps facing the front of the bike so you can periodically tighten them. The vibrations from the motor may loosen them. I check them at every oil change for cheap insurance.
Hope this helps.
Dave
Oh...and am I happy with it? Yes. Oil temps are always stable now, and don't go above 200-210.
