Does anybody have the agitator wheels on a 09 or newer Ultra Classic? I have been debating on putting a set of these on my bike this spring. If you did, what rear and front sizes did you go with, what rubber did you put on them? How does your bike now handle? Any information I could get to help make this decision would be appreciated.
Installed 18" front and rear . Haven't had a chance to try them out yet winter up here and working to much looks pretty good though spinning them ha ha
Looking to do the 19" front and 18" rear on my '10 EGC. From what I've found so far is that Dunlop only makes the 19" front tire for Harley in the 130/60B 19 size. I'm not sure of the size for the 18" rear. I'm also curious if you could run a 200 in the back. These wheels are pretty new, I'm hoping some of the guys running both wheels chime in.
Do any of you have ABS and if so how do you handle it. Different wheel or tire size changes the sensor readings and will effect the way they work or not work?
