What will it take to make my 07 flhx run with 09 cvo rk?
Old 02-17-2011, 10:54 AM
2002silverex's Avatar
2002silverex
2002silverex is offline
Is that 120r available yet?
Old 02-17-2011, 10:55 AM
DMorr99's Avatar
DMorr99
DMorr99 is offline
Check out H-D part number 19176-11. That is the same engine your dad has in his so he won't be able to out run you anymore unless he's just a better rider!
Old 02-17-2011, 11:01 AM
2002silverex
Im really liking what Im ready about the FuelMoto 107. Seems like a very reliable straight forward cost effective build....
Old 02-17-2011, 11:09 AM
flash1034's Avatar
flash1034
flash1034 is offline
Keep in mind it's a Hardly Ableson and not a 4 cyl Jap or Italian bike. If thats what your used to, youll be chasing your tail a long time looking for the same performance.
Flash
Old 02-17-2011, 11:40 AM
my67pnycar's Avatar
my67pnycar
my67pnycar is offline
If money is not an issue, why dont you have your local stealership find you a CVO SG then when it gets there have it upgraded with cams? There ya go, simple solution. That will be $50.00, lmao.
Old 02-17-2011, 11:55 AM
whistlebritches's Avatar
whistlebritches
whistlebritches is offline
Originally Posted by 2002silverex
I've got a 2007 street glide. Its the 96ci with Arlenes Big Sucker, Rinehart duals, and ecu flash.
My father has a 2009 CVO Road King, with just slipons, all else stock.
Im wondering what it will take to make my bike run with his, or better would be great.
Money isn't an issue, I just want the bike to remain reliable, and I don't want it to run choppy.
Thanks in advance,
Tyler
easy to do....R&R heads....woods 9b gear cam...51 or 55mm TB....Axtell jugs and pistons...the head/cam combo with a d&d pipe will bust his hiney
Old 02-17-2011, 12:22 PM
2002silverex
My dealer has two cvo street glides. When I said money wasnt an issue I was talking around $5000 for motor work, not $32,000.00
Im sorry, I should have specified, actually I shouldnt have even said Money wasnt an issue, becuase it is. If it wasn't I would have kept my cbr1000rr and I would have bought a brand new SG, not a 2007
Old 02-17-2011, 03:00 PM
cmcsns's Avatar
cmcsns
cmcsns is offline
Location: Beverly Hills, Fl. Swimmin pools. Movie stars
lkr0do a 107 from GMR, HQs, Fuel Moto, T-Man, Hillside--you will need about $4200 to $4600 including labor to get it done
Nothing wrong with a good running 107 kit, all pretty straight forward as builds go. There's plenty of reputable shops out there to choose from so look around a bit and I'm sure you'll find what works for you
Old 02-17-2011, 03:13 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
The fastest and easiest is to bolt in the SE120R at 145 crank hp and blow the CVO into the past.
Old 02-18-2011, 05:24 AM
2002silverex
My dealer is telling me to do the ACR but fuel moto says its not necessary for the 107....what are your feelings? ACR is $900!!
Quick Reply: What will it take to make my 07 flhx run with 09 cvo rk?
