Best Heated Grips
Old 02-17-2011, 01:28 AM
Smyln's Avatar
Smyln
Smyln is offline
Default Best Heated Grips
What is the best way to heat my grips?
Old 02-17-2011, 02:27 AM
Trailfndr's Avatar
Trailfndr
Trailfndr is offline
http://www.heatdemons.com/
Allows you to use any grip you desire.
Old 02-17-2011, 03:56 AM
karbar99's Avatar
karbar99
karbar99 is offline
Leave your bike sit out in the HOT sun. That should heat your grips.
Old 02-17-2011, 04:29 AM
jjnoble's Avatar
jjnoble
jjnoble is offline
+1 on the heat demons, but if you have Chubby 1 1/4 bars (575) they won't work, ID of the bars is too small for them to fit.
Old 02-17-2011, 05:10 AM
jakesaysiyaoyas's Avatar
jakesaysiyaoyas
jakesaysiyaoyas is offline
if your just trying to keep your fingers from freezing, i would check out gerbings heated gloves, gerbings.com, you wont be able to cook hotdogs on your grips, but its way easier and probably cheaper, and allows for upgrades to other heated gear, jacket liner, pants liner, even insoles
Old 02-17-2011, 06:22 AM
bogieb's Avatar
bogieb
bogieb is offline
+10!!!
Old 02-17-2011, 06:37 AM
steelerdude1's Avatar
steelerdude1
steelerdude1 is offline
I just installed Heat Demons, awesome product, works great! Looks Stock. I finally got to test mine the other day, I had to turn the temp down, because my hands started sweating.
Old 02-17-2011, 06:45 AM
Smyln's Avatar
Smyln
Smyln is offline
Steeler dude
awesome. how difficult was it to drill the hole in the handle bar?
How many hours did the install take? and total cost for kit?
Thanks
STEELERS ROCK!!
Old 02-17-2011, 07:17 AM
viperr817's Avatar
viperr817
viperr817 is offline
Not too bad to drill hole at all. For me it took about an hour and a half, I have done it three times so far. I did heat sharing all the in fairing connections. On another note, I have heated grips and thumb warmer on my quad which are made by symtec who makes the demons. And my left side quite working, the element burned out. So I called them and they sent me a brand new one for free! They stand behind their American made products!
Old 02-17-2011, 07:39 AM
SHAKEME's Avatar
SHAKEME
SHAKEME is offline
Default Gerbing rulez
The heated Grips will be good for shorter Trips, but if you do long rides in chilly winds,
forget heated Grips, they just heat the innerside of your Hands. Gloves will heat your finger/hand all arround. And even better are the heated socks. Both with PWM-Switches (pulse width modulation). The only thing i miss on my bike in the wintertime are Spikes.
Greez from Germany
ShakeMe
JTM65 (04-23-2022)
Quick Reply: Best Heated Grips
