Best Heated Grips
Old 03-08-2011, 11:03 AM
D'Artagnan's Avatar
D'Artagnan
D'Artagnan is offline
I've had the Heat Demons for about a year now and really like them. It wasn't until recently that I discovered that if you hold down the switch a couple seconds, the indicator lights will dim for night riding. Just thought I'd throw that in.
Old 03-08-2011, 12:01 PM
Traceman's Avatar
Traceman
Traceman is offline
I just installed my Heat Demons Sunday night and I think they are going to be great. My Kuryakyn grips got so hot I wouldn't want my bare hand on there on the highest setting.
If you go with them PM me for some install tips I learned. I even posted a little about the install the other day.
Old 03-08-2011, 02:10 PM
VINNIE JAMES's Avatar
VINNIE JAMES
VINNIE JAMES is offline
i have hd heated grips. they work when they want to. they were on my bike when i bought it. they are worn out and its time to up grade. i will look at heat demons
Old 03-08-2011, 02:14 PM
jjnoble's Avatar
jjnoble
jjnoble is offline
Originally Posted by jellen2
Heat Demon does have kits to fit the Chub bars. All distributors do not list them in cataloges and some dealers do not know about them, but they now have an application for almost every configuration. Go to www.heatdemon.com or call the company (number is on the website). Note the new logo and look - it's pretty cool!!!
All I see on the web site are these, it says Excludes 1 1/4" chubbys. Am I missing something? Not all 1 1/4 bars are the same, the chubbys are thicker than most and the ID is smaller.
B. Designed for all ' 08 & newer with Electronic throttle (Touring Class) :
*Excludes CVO Road Glide, CVO Street Glide and
CVO Ultra Classic Electra Glide
**Excludes after market 1 1/4" chubby bars for ET
Choose from one of the following kits for your bike:
210045CET - Chrome ET Left Mount
210045CRET - Chrome ET Right Mount
210046BET - Black ET Left Mount
210046BRET - Black ET Right Mount
210045CETCHUB - Chrome ET 1 1/4" Left Mount
210046BETCHUB - Black ET 1 1/4" Left Mount
Old 03-08-2011, 03:49 PM
NMNSG08's Avatar
NMNSG08
NMNSG08 is offline
Heat demons 100%!
Old 03-09-2011, 06:40 AM
Traceman's Avatar
Traceman
Traceman is offline
[QUOTE=jjnoble;8018847][FONT=Times New Roman][SIZE=2]
[SIZE=3]All I see on the web site are these, it says Excludes 1 1/4" chubbys. Am I missing something? Not all 1 1/4 bars are the same, the chubbys are thicker than most and the ID is smaller.
They sell some for Chubby's. That is what I have on my bike. If you try to use the regular ones on Chubbys you will have to ream out the ends of the handlebars a little so they fit.
D'Artagnan.....Thats good to know about being able to dim them. I missed that in the paperwork if it was even in there.
Old 03-09-2011, 06:45 AM
jjnoble's Avatar
jjnoble
jjnoble is offline
D'Artagnan.....Thats good to know about being able to dim them. I missed that in the paperwork if it was even in there.[/quote]
Okay, I'll give them a call. Thanks.
Old 03-09-2011, 06:58 AM
Traceman's Avatar
Traceman
Traceman is offline
Check this out jjnoble
Ebay item=320609537872
Old 03-09-2011, 07:41 AM
uscanuck's Avatar
uscanuck
uscanuck is offline
[quote=Traceman;8021760]
Originally Posted by jjnoble
[font=Times New Roman][size=2]
[size=3]All I see on the web site are these, it says Excludes 1 1/4" chubbys. Am I missing something? Not all 1 1/4 bars are the same, the chubbys are thicker than most and the ID is smaller.
So you have Wild 1 bars and the 1-1/4" heat demons worked without reaming the inside of the bar?
Does the controller actually need to be fitted over the 1-1/4" bar? Right now my clutch is on the 1" side.
Old 03-09-2011, 07:53 AM
Traceman's Avatar
Traceman
Traceman is offline
[QUOTE=uscanuck;8021929]
Thats correct. They were made for them. If you look at the ebay item I posted above they have them. The controller just replaces your existing clutch clamp cap. (say that 3 times fast LOL) The Chubby bars are turned down in the grip/control areas so that all your stock hardware works.
You can see in the picture how the ends are smaller.
Quick Reply: Best Heated Grips
