Idle for a 2010 96" fuel injection
My 2010 EG with the fly-by-wire throttle idles at between 960 and 1000 rpm when warm. It sounds a little high to me. What should the normal idle be and can I adjust it or does it have to be hooked up to a computer at a dealer?
I have not done a stage one yet, only replaced the stock mufflers with Rush slip on' s.
Thanks
Thanks
Kim,
if you are in the habit of using the kill switch, this can confuse the ECM as to "0" throttle setting.
If you find the idle on start up being way high ( like 1700 rpm- 1300 or so is normal for cold start up), cycle your ign switch on/off a few times.
that should reset the ECM "0" throttle sensor reading.
I'm still trying to get used to using the ign switch...
Mike
Mike
Kim,
Mike
Mike
Thanks for the information Mike,
I do normally shut it down with the kill switch. Never had it go as high as 1700, always around 1000. I will start using the ing switch if I can remember!!
Kim
Bluehighways
02-24-2011 08:17 PM
