TBW grip problem
TBW grip problem--problem solved
While riding yesterday, I suddenly lost throttle control. At first I thought the bike had gone to the limp mode, but it didn't. I could use the throttle for acceleration, but when closing the throttle all the tension was gone. I rode home and noticed that I could turn the grip completely around in the closing direction with no resistance. I removed the grip and could not find any problem. The sensor at the end of the handle bar seems fine. I can't see into the grip very well to see if there is a problem with the splines. They are ISO grips. Anyone else experience anything similar?
Not 100% clear. Do you mean the return "spring" is gone so you have to roll forward with your hand? If yes.....then mine has been like that for over a year. Some have suggested loosening the torx on the housing and moving it out just a fraction, apparently some have experienced binding.
I have gotten so used to it that way I have not bothered yet. Sorry for the long reply if your issue is different.
Similar Problem
I had something like this happen. When I would shut the thottle I could turn the grip past the stop. It was HD after market grips. Seem they are a two piece unit. The splines inside were fine, the outside was just spinning on the inside sheath. Took it apart, cleaned it up, and glued it together. Still working fine.
