stuck throttle
stuck throttle
I have a 97 FLHRI with a stuck throttle. I cannot advance the throttle at all. The bike starts and runs ok I just can't go anywhere! I've taken the handlebar assembly apart and nothing appears out of the ordinary. Nor do I detect any damage to either the idle or throttle cables. It does not have cruise control. Any help would be appreciated.
thanks,
thanks,
FLHRI---- injected.
as suggested remove air cleaner and visually check that throttle plates are opening and closing with throttle grip.
I believe you have an idle speed control at the 4 o'clock position when looking at the backing plate- you could see if the adjuster has managed to vibrate in
Mike
Mike
