LED Signal Fitment
LED Signal Fitment
Seems like plug-n-play means grind down before it fits....
Got the Radiantz LED front and rear turn signals, trying to install them today..They will not seat in the bullet housing or insert into the lens. I had to Dremal the round circuit board to get them to fit.
Anyone else encounter that issue............
DUHHHHHHHH....After using the Dremal on the two back unit.......I came to and realized that that wire was the culprit, once I twisted the unit around inside the housing to spool the wire, the lens fit fine......Maybe by me posting this will help another member suffering a senior moment....
Those 5 minute jobs always turn into hour jobs...
Got the 1157 (dual contact) style for the fronts and the 1156 (single contact) style for the rear. The Ultra styles I believe have holes in the circuit board for the lens screws to go through.
HDV-Glide,
Are those from Custom Dynamics? I am getting ready to order their LED turnsignal kit for my StreetGlide. I have the push/plug bulb LEDs running now in the rear. CD is telling me a load equalizer is required if I go with their lights for both front and rear. The LED ones you find at AutoZone and truck stops only have 12 LEDs per bulb while the CD units have 48. I want bright lights as my turnsignals are ALSO the rear brake lights on the 2010 StreetGlide. Post some photos with your working.
HDV-Glide,
http://www.radiantz.com/index1.html?c49.html&1
They sell the Biketronic Equalizer also.
I got the white for the front and the amber for the rear.
Apologize for butting in here...
I'm looking for a rear tail light/brake light LED bulb only - to be brighter than what I have. Keeping my stock red lens.
Did I read correctly that I can just get one at the truck stop? Plug and play?
I have the all red running lights in back. I like them but I don't think the center run/brake
light is bright enough (among the 3 red lights). Don't want to spend lots of $$ replacing lens, adding equalizer etc. Just want it to stand out and brake a brighter red. Is that what this discussion is basically about? I thought I'd get a clear bulb.....
