ATTENTION: Draggin' Bagger ISSUES
#51
RE: ATTENTION: Draggin' Bagger ISSUES
If it was me I would have a air pressure gauge installed and would take note of the maximum suspension height without hitting the mufflers by the pressure on the gauge. I highly doubt there will be a fix for shock bolts hitting mufflers because its something that can't be changed, the shocks are where they are and theres nothing anybody going to do about that. I don't see why anybody would need to pump the shocks up to full extension anyway as nobody ever going to ride it like that. If a person had a gauge you could figure out ideal pressures for solo riding, two up, two up with gear etc, and eliminate any guess work. I myself haven't ordered a system and most likely won't, but it looks like some quality parts with excellent customer service and extremely low price.
#52
#53
#55
#57
ORIGINAL: gunrunner
The shocks are car air shocks thats why they are rated at 150, used them 35 years ago on all my hotrods, hurst were the best, having no visable rubber bladder. but anyway, they should lift to max height well below that pressure.
Personally I bought this system for the convenience of not having to remove the saddle bags to change the air pressure when riding two-up and to get my feet flat on the ground at stops. I had already tried lowering the bike using a 1 1/4" So-Low kit then a 1 3/4" R.U.B. kit to get flat footed. I also lower the front 1" with the HD kit. I achieved flat foot with the RUB kit, but had to jack the presure up in the rear shocks so high that it was uncomfortable, two-up riding was down right unbearable requiring 40-45 PSI in order not to rub the rear fender. With the DB system I can ride lower than I did with the RUB kit without rubbing or having a harsh ride. I can adjust the height as desired with just a flip of a switch. So in the end this system gave me exactly what I needed to make riding my Street Glide the joy that it should be. I would never had considered a Legends system or other air ride manufacturer given their high price. So far the few problems that have arisen are minor and have been addressed appropriately and quickly by the manufacturer (Tony) at his own expense. In a lot of ways we here on this forum have been Tony's R&D and as a result the kit has been improved upon. I'm beginnng to get just a little annoyed by the people who want to say that I "got what I paid for". So far this kit has worked flawlessly for me and for countless others. I'm sure not every Legends kit has worked flawlessly especially at thier beginnings. I applaud Tony for taking initiative and starting a business like this, I only wish I had thought of it first . Over time I'm sure his system will only get better as better parts become available and/or he learns through these early kits what works and what doesn't.
#58
ORIGINAL: roseroid
jmorton10: It works never a problem,! Show me a pic of your bagger, always interested in what everyone else has, "see's" and does to there RIDES. !! YOU..............now.......
roid
roid
Here is an old pic(I have since swapped the exhaust to a Supertrapp Supermeg)
http://www.pbase.com/jmorton10/image/47853108
~John
#59
ORIGINAL: bdjhog
Me either. I am willing to try the DB system for $400 myself without a 2nd thought however(heck, you could buy 4 DB systems for what the Legend system costs).
I have 12" standard spring Progressive 440's on my bike now & the ride is outstanding. My problem is, I am only 5'6" & I could really use a lower height for very low speed handling (backing out of parking spaces etc).
For $400 I bet it works just fine, but if I am not happy with the ride I will remove the system & sell it to somebody here at a great price & reinstall the Progressive's.
~John
#60
mine works fine...dont leak....it dont hit no bolt when youre on it...just abuncha bit@hy wannahave's that aint got...i'd rather give any of you 2k than spend that kind of silly money on the same stuff...cause its the same compressor...same lines....same fittings...maybe different shocks but inside they'll be damn near the same...if ole roid had bought the DB system, he coulda put some real pipes on that bike he's got with the money he saved
