Adjustable cam gear
Old 02-12-2011, 09:17 PM
harleyheaven's Avatar
harleyheaven
harleyheaven is offline
What interests me more than the numbers increase is moving the torque curve further to the left. I would be interested in taliking with them to hear any thoughts about my build.
Old 02-12-2011, 09:38 PM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 16,111 Likes on 5,014 Posts
Originally Posted by black ice ultra
I have the cam gear on my bike. It is a good thing if you know anything about hot rodding,and engines you would know that timing of your engine to get the most out your cam is a good thing. Better gas mileage and more hp and tq. To get the gains from just timing your cams with the gear. you would have to spend a lot more money. I gained 5 in hp and 10 in tq. just by timing the cam. Hemrick performance can get the most out of your set up using the cam gear.
I believe you, and its very true, those last few hp's are the most expensive!!. gas mileage went up because efficency went up. I'm a mercedes mechanic, and we've used variable cam timing for years, (it moves as you drive, this doesn't, I know), glad it got it all for ya!
Old 02-12-2011, 10:39 PM
VibratingPotato's Avatar
VibratingPotato
VibratingPotato is offline
I got a '08 EG with 28k miles.
I just finished a 107 build and I measured everything.
When I degreed the cams, they were basically 4* advanced using the stock cam chain and sprockets.
Maybe the chain is stretched or something is machined off.
If you need to put your cam in straight up or wherever you want, a degree wheel and an adjustable sprocket would be the way to go.
Old 02-12-2011, 11:19 PM
$tonecold's Avatar
$tonecold
$tonecold is offline
Received 1,854 Likes on 1,001 Posts
Default It Adjusts Both Ways
The adjustable cam gear lets you go 10 degrees advance or retarded, so if your cam is advanced with the stock gear you could zero it with this gear. HarleyHeaven, if you go on Hemrick's website, www.hemrickperformance.com I think, he has a tutorial on the gear. According to him advancing the cam timing does move the torque curve down the rpm scale. My tuner wasn't the most co-operative about the whole thing, so I only have the final dyno sheet on my tune.
Old 02-13-2011, 03:47 PM
2D3K1H1B1HIM's Avatar
2D3K1H1B1HIM
2D3K1H1B1HIM is offline
So what its doi'n is to adjust timing to whatever cam you have,kinda finding the SWEET SPOT of the cam.!!!!
Old 02-13-2011, 07:13 PM
$tonecold's Avatar
$tonecold
Default Sweet Spot
That is basically correct about finding the sweet spot. It is actually a little more involved. If your cam is timed correctly you will not have inversion in your exhaust, which is the gasses moving backwards toward the engine. That is what anti reversion cones are all about, but if the cam timing is right they're useless. Like I said, go to Hemricks website and look at the tutorial, he explains it very well.
FatBob2018
Milwaukee Eight (M8)
72
10-17-2021 08:59 AM
Sledman
31
07-05-2020 12:18 PM
cdonis
Engine Mechanical Topics
21
02-17-2015 03:26 PM
NTrain177
03-28-2012 05:42 PM
nosillyname
09-27-2009 08:51 AM
Quick Reply: Adjustable cam gear
