Which Heated Grips
I had HD heated grips on my 04 Dyna and they worked well. On my 09 FLH I had the dealer install factory grips as I was a little concerned about doing it myself what with TBW. I hadn't used them much when they started acting up. They wouldn't get very warm. I pulled the front off to check the wiring and found the "tech" had simply snap connected the hot lead to the cigarette lighter wire rather than running it back to the fuse box. The service dept did replace the grips and wired them correctly and they've worked fine ever since. After reading the posts here recommending Heat Demons, if I were doing it again I would give them a look.
Riding with heated grips for years, on many different bikes, I can't imagine not having them. They're always there and I find myself using them a lot. If you're riding in really cold temps with no wind protection for your hands you may want to use heated gloves. But on my GS with hand guards, and the Electra Glide with its fairing, I've never found the need to use the heated gloves. In fact come to think of it while I do use my heated jacket liner, I haven't used my heated gloves in years.
joyryd68
09-22-2013 03:23 PM
