Tried to put some air pressure in the rear shocks on my '05 EG Classic today. I was using a simple Bell bicycle hand pump. I could not pump any air through the valve at all. Only had the bike about a month, so this was the first time I've tried adding air pressure. There is no pressure at all. Any ideas?
You will need to use a pump made with the correct fitting to fit the valve. The schrader valve is positioned lower inside the fitting thus needing the correct pump. The lines are not the limiting factor as far as air pressure, they would hold 150 psi or even greater. The issue is the shock seal.
Thanks, kruzin. Your diagnosis sounds accurate. Any ideas where to get a HD pump, other than the super expensive dealer?
