Damaged Swingarm
Damaged Swingarm
I need help with ideas or part numbers, so upset that I cant think straignt.
I was trying to install the True-Track Tracula kit which calls for pressing out the Spherical bearings, deburring and installing the True-Pivot by pressing. I was attempting to press out the original bearings and instead of the bearing moving the ear of the swingarm bent in. I believe it will require replaceing due to alignment issues with transmisson and rear wheel.
Does anyone have a part number and idea of price?
Picture attached.
2007 FLHT
Picture attached.
2007 FLHT
Closer inspection shows that I was pressing the Spherical bearing in the wrong direction. I know, measure twice, cut onec, read instructions, leave it to a professional. Trying to work on my own bike and it is becoming an expensive learning experience.
I dont know if swingarms can be reworked or if it is strictly a replacement item. Any help would be appreciated. I already feel bad enough as is.
That part is for model years '02 to '08
It changed in '09 due to the wider wheels/tires.
