Power comander Autotune
I had reset my target AFR values in the auto tune,, well i thought i did ,, I went for a ride to see what it was doing when i got back home I checked it and I found out it did not change it to my new settings, it went back to the old setting , ok so when one changes the target AFR values in the auto tune then how does one save it .
thanks
thanks
First, make sure you have firmware v0.1.4.0 on the PCV and PCV software v1.0.3.3 on your computer. Some older versions of the software would not save changes properly. To change any setting like target AFR's, follow this procedure after connecting your PCV to the computer via USB and launching the program:
1. Click on "Get Map" on the bottom-left of the main window to load the map and settings from the PCV to the software. It should already be loaded when the program is launched, but this auto-load feature can be switched off.
2. Click on the Target AFR table for each cylinder and make your changes.
3. Click on "Send Map." This sends the map including changes to the PCV. If you don't do this the PCV will not get the changes.
4. Click on "Save Map" if you want to save it to a file on your computer. I save all previous map variations, before and after changes, just in case I want to revert to or reference one of them in the future.
If it still won't save the changes we may need to flag-down Jamie for help.
To me the advantages of AT include the ability of making changes for unusual builds or frequent changes that go outside FM's map database. It is also good for incorrigible tweakers like me who like to experiment with various AFR and other values to maximize gas mileage, etc. If this sounds like your cup of tea I would recommend AT, but I think most riders can do very well with just a PCV and a good map from FM. My 2¢.
