Backrest pad
Received 74,920 Likes
Like this?
Manufacturer Part Number: 52935-04/51727-05
http://cgi.ebay.com/ebaymotors/Harle...Q5fAccessories
That's as small as they come for the tour-ers.
[QUOTE=lionsm13;7882738]Like this?
That's as small as they come for the tour-ers.[ Yeah, I was thinking of getting the short bar....but that one is for up to an 08....wont fit the 09 & up but thanks!]
[QUOTE=teleman001;7882773]
They do make them for the 09's and up though FYI..
Good Hunting.
Like this?
Good Hunting.
Bought my '11 SG in October & installed detachable sissybar. Immediately my wife said she didn't have as much room as on my '00 softail. We measured & if I remember correctly, there is 4" less roon on the touring bike than on the old softail! I set out to bend it back to give us more room. Man that sucker is strong. I turned it upside down (picture an inverted V)with padding on it and bolted an oak stairtread to both sides of the sissybar upright. I then drove my F-150 up the "ramp" formed by the inverted sissybar in an attempt to straighten out the bend a little bit. The sissybar did not bend at all!! What finally worked was taking a sledgehammer to it. I again laid the sissybar upside down (with the bend of the bar up) and layed an oak 3x4 across the bend and wailed away at it with the sledge. It finally bent! We were able to bend it back a couple inches (without cracking the chrome) which certainly helped but it could still stand to be roomier. A thin backrest pad would probably give an additional inch. I am surprised no aftermarket mfg hasn't come up with a revised design.
Check with Mean City Cycles and see what they can do. I'm thinking they could reduce the thickness by 50% and replace the original padding with some memory foam or something.
You're right, there isn't as much room on the glide as there is the softail. My wife says the same thing.. I don't know if I want to go that trouble thought that you did LOLOL!!
