M&M giving me fits
#31
#32
#33
Thanks for all the responses, sometimes you can forget about the simple things & someone will say something & then it clicks. I did not want to find the injector bad, since I just bought them last year, I think that is why it took longer that it should have. Spoke too soon as for it running well, I should have fraised it that the rear cyl is back to running. Took it out on a rode test & as long as I am giving it throttle, it runs great, but at cruise or idle it is popping through the throttle body. I sprayed it down while it was running & don't seem to have a intake leak. I do have SE adjustable push rods that I had readjusted about 4-5 months ago. I set them @ 8 1/4 turns which would be 2 turns, so I don't think they are too tight. The instructions that came with it said 2.5 turns, I think it makes less valve train noise @ 2 turns. Guess I will try to get a look on the back side to see if I rolled the intake gaskets.
Toby
Toby
#34
Good news, it is not my caliper that is leaking. Bad news is it is the front fork. Did get the Ultra running, it was the intake gaskets (rubber rings). I did not roll one but they were thinner than the originals, so I don't think they were getting pushed up against the head good enough. Took it out & rode it a little then took it back & changed the oil in the engine & trans & washed it. Poor thing has not had a bath for several months. Next project is the front seals in the forks & change out the fluid. Gonna ride tomorrow to work.
Toby
Toby
JR-Boston
01-09-2015 11:04 AM
