M&M giving me fits
Since last week I have been sick, working late & worked on a friends car, so I have not got out on the bike until this afternoon. Good news is it was a bad fuel injector, bad news is I bought a cam sensor, cam chest gasket, throttle & clutch cables plus found a crack on my exhaust. But I am on the down hill side. I put the good injector that I put in last year to the rear cyl & put the good injector that I pulled out last year to install the new injectors & put that one in the front. Starts & idles great, snap the throttle & it revs up great, now to get it back together. Will it ever end so I can just ride?
Toby
Toby
Toby
Toby
If you plan on keeping the bike you can install the new fi system that zippers has to replace it.A little expensive but i did it on mine and it was the best thing i ever did to that bike.It ran flawlesly for 2 years and even until now since i still ride with the guy i sold it to.It has never had any problems and all he has done is change fluids.
Thanks Captain Itch, hope to be getting some of your thigh coolers soon.
Toby
Got my new cables (clutch & throttle) on, pulled the cam chest to inspect the tensioners (looked like new @ 30,000 miles), welded my exhaust (it had a crack) & installed a new cam sensor. Just don't like the way the clutch cable is routed around the frame & have tried it in several different ways. I can't decide if it goes on the inner part of the frame, just past the brace & then to the outside of frame & then the inside of the crash bar & then up to the inner fairing. Right now I have it on the inner part of the frame but it looks like it is too close to the engine. I think sometimes I look at something & say to my self I can remember that, & then bam, I forget. Should have taken pictures. Then I noticed a puddle of brake fluid under my front tire. Will it ever end? Now I need to pull the inner fairing cap off to change the fork oil (have not done it since I have owned it so it is due). Still have not found the problem with the radio (which if it doesn't work, I can still ride). Hope to have it together soon so I can ride.
Toby
Toby
Bubbas1 in step #16 https://www.hdforums.com/forum/touri...ep-w-pics.html Is that your clutch cable on the right side of the triple tree? I know mine was routed on the left side but had a wear mark on the cable from the deflector plate & your pic may have solved my dilemma.
Toby
Toby
As to the routing of the clutch cable, on my 07 the cable goes to the backside of the engine guard, the outside of the left downtube to the bottom inside of the right downtube then along the upper part of the right side frame tube to the transmission.
If you have a cracked exhaust pipe then you also probably have a broken front motor mount.
