air pump
10-05-2006 | 09:03 PM
air pump
Does anyone have an onboard air pump that will pump up and let down the rear shocks, as well as fill a flat tire if need be? What kind,and where to get one?
10-05-2006 | 09:11 PM
RE: air pump
draggin baggers has an onboard compressor....you could easily T off the comp to a fitting for tire air...fixaflat and a can of air works well tho
10-05-2006 | 09:31 PM
RE: air pump
Would you have a web address for draggin baggers? thanks Dan.
10-05-2006 | 09:37 PM
RE: air pump
dragginbaggers.com
10-05-2006 | 09:38 PM
RE: air pump
www.dragginbaggers.com CAN'T put a compressor to Harley shocks...hand pump only! COULD put a bypass valve on the DB system to pump up tires.
Mixter
03-04-2011 09:49 PM
cfs754
04-06-2009 06:48 PM
agent58
04-30-2008 01:53 PM
Barton
11-30-2007 03:44 PM
kingultra
10-08-2006 02:29 AM
