Which throttle body/fuel injectors?
Here is my build: 2004 Road king FLHRI
95" kit
Screemin eagle 10:5:1 flat top pistons
hydraulic/high output pump with tw 60 cams
mcr se heads with manual compression releases
My question is, is it worth it to buy a bigger throttle body and bigger injectors? I'm sure it is to improve air and fuel to my motor. If so what size throttle body should I go with? I believe mine is a 48mm stock one. Please give me detailed answer. Thanks so much....AJ
95" kit
you'll do just fine with a "worked" stock TB...hillside or gmr can do it for you....on the injectors, use the SE 25deg ones for an 06 SG.....anything else will be overkill on both the engine and your wallet....been there on both sides with HPI & Marren inj, runs better with a bored out stock TB and SE inj for half the money
skinman13
08-11-2021 05:50 PM
Bluehighways
01-18-2019 08:23 PM
adm
20
02-15-2016 04:24 PM
twism_23
Exhaust System Topics
32
12-22-2012 09:31 AM
