HD Crash bar mounted fog light, review & install???'s
#31
Huh??? The Rigid LED are the way to go, brighter and pull less wattage. These are almost twice the lumens as the HD ones.
These work fine
http://www.rigidindustries.com/SR-M-...-p/sr-m-fl.htm
and there are caliper mounted lights
http://www.superbrightleds.com/morei...rk-light/1386/
These work fine
#32
#34
#35
There is no easy way of answering your question, except to say simply that C is a successor of B. The parts are interchangeable and the difference may be an improvement in the design, or change of supplier, something of that sort. Given the choice of a B or C I personally would chose the later one.
#36
#37
I've tried LED bulbs in mine and they wouldn't fit, they are too big! Do you recall which brand you have in yours? The problem with many LED bulbs is that they are bigger than stock types.
#38
sailnbike
Touring Parts
11-09-2012 12:16 PM
Rhetor
06-24-2011 11:32 PM
