I just put my deposit on a 120R, my dealer said I have to use a screaming eagle intake but dont like the options. I just put a RSD intake on last fall does any one know if they make a back plate to fit the 58mm throttle body?
RSD does not make a backing plates for the 58mm, already called. I was trying to keep my RSD A/C as well. Getting my 120r installed this week. I will let you know if it can be adapted to fit the 58mm.
I too am in the camp that doesn't much care for the SE "Heavy Breather" type filter. There is an SE filter kit that looks like it would allow other brand air cleaner covers to be used. HD part number 29515-08 looks to have a filter similar to the Zipper's upgraded filter in width. Perhaps the RSD cover you have would bolt on to this filter?
