New Rockford Fosgate mini amp?
Old 02-19-2011, 03:45 PM
neano62's Avatar
neano62
neano62 is offline
I talked to Yaffe last wkd. in Columbus,Ohio at the EZRider Show.
He said he should have everything in a couple weeks! and for a couple Hundro,...plus he said you can stack these amps, I'm believing this is gonna b 1 "Hot" item.
I'm ready for 600 watts of "Power" for my Motorcycle "Sound System"
Old 02-19-2011, 04:09 PM
GLACIERPEARL's Avatar
GLACIERPEARL
GLACIERPEARL is offline
Each amp is 300 watts @ 4ch. How many speakers are you running ??
The 4 ch amp should handle 99% of most biker's needs.
At 75 watts per channel, it should do a good job at powering the 7 1/4, 6 1/2 & 5 1/4 speakers that everyone is running.
Unless you are running more than 4 speakers,....the "stackable" part of the equation is a moot point.
Old 02-19-2011, 04:18 PM
Strat HD's Avatar
Strat HD
Strat HD is offline
The amp is switchable to a two channel. Of course switching it to two channel will give more watts. That spec has'nt been given yet though. Two amps switched to 2 channel ran to four speakers.
Old 02-19-2011, 05:49 PM
neano62's Avatar
neano62
neano62 is offline
2-6x9's CycleSound Lids
@-Rockford Fosgate Shallow mount 6.5" Coaxial New "Power" Series(Inner Fairing, like Yaffe's)
and 2 6.5" in stock holes,just not sure which ones yet, Hawg-Wired, Focal, I've got Titan-Hertz Hi-Energy rite now.
So 6 speakers total.
I'm not lookn to impress anyone but "Myself"
Old 02-19-2011, 06:12 PM
GLACIERPEARL
How do you plan to wire the speakers/amps ?
What speakers come in the cycle sounds lids ??
Old 02-19-2011, 07:07 PM
alkrisma's Avatar
alkrisma
alkrisma is offline
re: a 2011 flhx with stock head unit (4 ohm): an amp should be 4 ohm and speakers 2 ohm, correct?
Old 02-19-2011, 07:10 PM
GLACIERPEARL
Stock head unit is 2 ohm !!
Old 02-19-2011, 07:14 PM
alkrisma's Avatar
alkrisma
alkrisma is offline
oh, ok. thought it was 4, thanks. so the amp and speakers must also be 2 ohm, correct? or not?
Old 02-19-2011, 07:16 PM
GLACIERPEARL
Old 02-19-2011, 07:21 PM
shore's Avatar
shore
shore is offline
You need 2-ohm speakers unless you are using an amp. The a must be 2-ohm stable also. Most good ones are.
Quick Reply: New Rockford Fosgate mini amp?
