for the time being, think the cam will be enough,would like to have fuelmoto 107 kit.but going to run this cam for a while, maybe next winter.what i have read on this forum think the cam will give me that little bit of extra torque that i am looking for.
With stock heads you would see about 85-92hp/105-110 tq. They say if you go with SE 1.725 rockers along with your cam you could see a little more tq across the board by getting a little more lift.
wahoo! just won a bid on se 204 cam for 155.00 less than 100 miles on them, cant wait to put them in my 103 in my ultra limited!!!!!
roger
Congrats on the win. Not trying to curb your enthusiasm but be aware that SE204s in a 103" are going to increase your compression toward the high end; static at 9.8, corrected at 9.3 and cranking compression north of 190psi. You will need a good tune and when the weather warms up, listen for detonation (pinging). A tank of chitty gas may also bring it on. Compression releases would help battery and starter on hot start; she will resist and want to kick back when hot.
The SE204 is a great bolt in cam but has wicked dynamic advance ground into the cam which makes it a hot little cam but also contributes to the issues mentioned above. You might consider installing it with a 4* retard gear. In the future, if you do some headwork and set the heads up for those cams, you can remove the retard gear and install them straight up.
