I was just wondering how many people out change their own tires and what kind of tire changer they use to do this? I am loking at getting one and just wanted to here some pro and cons of what people have and their experience with them.
Harbor Freight, spoons and rim protectors. A piece of cake after you figure things out!!! Go for it! I took the risk and now can change mine and my buddies tires!!! Also am using dyna beads for balancing!
Harbor Freight tire changer (item # 34542), Harbor Freight motorcycle wheel adaptor (item # 42927) if you can find it, Marc Parnes wheel balancer at marcparnes.com, the MOJOLEVER at home.comcast.net/~prestondrake/mojoweb.htm, a set of rim protectors, three good tire irons, a good rubber mallet, & some tire weights. Cost is around $300 +/-. You save that in two tire changes. The Harbor Freight changer has a bead breaker built in.
