Wish I was a little brighter
http://www.rallylights.com/Hella_7_i...Headlamps.aspx
http://www.rallylights.com/detail.aspx?ID=350 Headlamp
and go with the 80/100 watt bulbs and your headlight will be almost as bright as a HID unit.
I had a HID unit and swapped it out for those and the brightness is close but the distance you can see down the road blows the HID unit away...
All for about $80
All for about $80
My riding buddies tell me my headlight does not show up well during day rides and looks dimmer than my spotlights (passing lights, auxilliary lights, whatever) at night. I don't do a lot of night riding so not looking to light up the night or cause 1-finger salutes. Just looking for a set of bulbs for my headlight AND spotlights that will make me a little brighter with all three lights up front looking the same color. Some of the "brighter" headlights look blue or pink and don't match the spotlights. Hoping to find a set of relacement bulbs for an '09 Ultra that won't require new wiring, different housing or cause heat-related problems. Anti-vibration and long-lasting would be good, too. Anybody find a solution that doesn't require upgrading to HID or LED?
Also, you could install some higher-powered auxillary lamps in place of the stockers. I used 37.5w pencil-beams (CCI #15085) on my old RK and they were much better than stock. With their very narrow beam they need to be properly aimed or will blind everyone coming at you.
It's dim in daylight because it is on low-beam. I'll second HDV Glide by suggesting that you install an 80/100w bulb, which by itself would help, or go another step and buy a E-code headlight, neither of which will cost much. Both would help in daylight and make a huge difference in night visibility, but I think you get the best visibility running only the high-beams, preferably with a modulator. I did some tests about 10 years ago running both with friends observing from the front and most thought the high-beams were more visible. I ran these bulbs on my old RK and also on my '07 SG and never had a wiring or connector problem with the increased amperage or heat. A friend with a '98 Softail and another with a BMW did have problems with connectors melting, however, and they simply replaced them with a high-heat connector from Auto-Zone. FWIW, the modulator eliminates these problems on high-beam since they pulsate at 20-100% 4X/sec., and that reduces heat greatly and even prolongs the life of the bulb.
Lp, I was in front of an ultra classic that had the LED conversion in all three and can definitely attest that I was able to see the lights four blocks back. The color was very bright white. Just my observation. Now I want to convert to LED on my ultra. Just need to wait for the slush fund to grow some more.
Exactly! I had my auxilliary lights installed by the dealer when I bought the bike. The dealer told me they ALWAYS adjust the headlight down so all three lights together do not blind oncoming traffic and if it is not bright enough to adjust it up again. If the dealer installed your auxilliary lights I would check the alignment of the head light.
I'm going to save up and get the LEDs myself one day.
lp
