Need help finding new wheels for 07
Old 01-22-2011 | 11:51 PM
marvincbr's Avatar
marvincbr
Default Need help finding new wheels for 07
I thought I had it all figured out on getting HD Agitator rims for my RG, but it seems the rear 18" won't fit my slimmer swing arm. Could those of you that have updated the wheels on your 07 baggers post some pics of what you've got with sizes and if you had to do major modifications to make it work? It would be very helpful and much appreciated. Thank you,
Steve
Old 01-23-2011 | 06:09 PM
marvincbr's Avatar
marvincbr
Bump...
Old 01-24-2011 | 08:00 AM
grbrown's Avatar
grbrown
Originally Posted by marvincbr
Bump...
Ouch!
I have an 07 rear end in my older Glide and the widest tyre I can get in easily with a 16" wheel is a 150. A 160 may just squeeze in with luck, without touching the belt. It may be possible to use spacers to move the wheel away from the belt for a bit more room, but that will also mean messing with the brake.
Something to take into account, when running close to the limit with clearances back there, is that tyres can be quite different in fitted width to what it says on the sidewall. My Avon Venom 150/80 is actually 153mm wide on my 3" rim. From what I've seen here on HDF some 160s can be even wider still.
Hopefully someone with more experience will call by soon.
Old 01-24-2011 | 08:09 AM
07FLHT's Avatar
07FLHT
Anytime I start thinking about getting wheels I look through HogPro's gallery for inspiration...
http://hogpro.com/showpage.php?page=gallery2.htm
Old 01-24-2011 | 08:33 AM
MotorSgt's Avatar
MotorSgt
I just bought new rims for my 07 RKCustom. I kept the 16x3.5 in the rear and went with the 18x3.5 up front. I kept the rear the same size because tires are generally cheaper for a 16. You cant really see the rear wheel any how and it wont mess with the speedo. Go with the bigger wheel up front because you can actualy see it. Just my $.02
moeo7
09-30-2016 05:03 AM
gmanphd
03-30-2013 07:07 AM
AzSteve
11-26-2009 08:34 PM
bkshovel
12-14-2006 02:18 AM
PTS
07-20-2006 12:32 AM
Quick Reply: Need help finding new wheels for 07
