Strange Feeling on SG
Old 10-03-2006, 01:19 PM
Hardly Dangerous's Avatar
Hardly Dangerous
Hardly Dangerous is offline
Default Strange Feeling on SG
Did some touring in the mountains of Massachusetts this past weekend on my 06 SG and felt something strange. While cruising up a long uphill mountain road at about 80 mph I hit the gas. I'm not sure what rpm's it was but nothing happened. There was plenty of throttle left but no response. It was almost like I had a govenor on it. The bike runs good otherwise but shouldn't I have something left going uphill at 80 mph?
Old 10-03-2006, 01:24 PM
huffhuff's Avatar
huffhuff
huffhuff is offline
Default RE: Strange Feeling on SG
maybe it depends on the altitude changes you went thru. had a similar situation with a fuelie car. ran like crap climbing in colorado. stopped at a rest stop. shut it off for about 10 minutes. when i started it up again it was fine. some only calculate at startup not enroute. a drastic change will only be input on restart.
Old 10-03-2006, 01:25 PM
Akitakoi's Avatar
Akitakoi
Akitakoi is offline
What gear?
Old 10-03-2006, 01:34 PM
solorider's Avatar
solorider
solorider is offline
ORIGINAL: Akitakoi
What gear?
My question too. In 5th, at 80 m.p.h., going uphill, might seem like nothing is happening. These aren't Hyabusas...
Old 10-03-2006, 01:37 PM
dawg's Avatar
dawg
dawg is offline
Received 3,239 Likes on 1,850 Posts
Must be the Massachussetts smog
Old 10-03-2006, 02:25 PM
MACK's Avatar
MACK
MACK is offline
if you were heavily loaded in 5th at 80 theres hardly anything left uphill at that speed. maybe a little if it is injected. but if stock you got all you had.
Old 10-03-2006, 03:36 PM
Hardly Dangerous
I was in 5th gear. I think if I was in 4th it would be red lining (or close). I just thought there might be something more.
Old 10-03-2006, 06:46 PM
Sportshot's Avatar
Sportshot
Sportshot is offline
I bet you won't be anywhere close to redline in 4th gear at 80 mph. Try it sometime, you can run to 6000 rpm in 4th
Old 10-03-2006, 08:08 PM
buttman's Avatar
buttman
buttman is offline
HMMMmmmmmm.....just curious here......but, um, if you were going 80......up-hill.....on a mountain road........uh....why would you be wanting to "hit the gas"?????? HMMMMM?????
Inquiring minds want to know!!!!!
Old 10-03-2006, 10:13 PM
asuperheat's Avatar
asuperheat
asuperheat is offline
stock bike probably all she had uphill even here in florida not much more @80mph without motor work.
Quick Reply: Strange Feeling on SG
