Load Equalizers
I'm not a tech but I understand what fabrik8or posted regarding the low power draw of normal LED's tricking the TSSM and, hence, the need for a load equalizer.
I also understand that some LED products (e.g. HD LED's for tour paks, turn signals, etc.) come with a built in resistor(s) so the TSSM sees a higher power draw, and thus avoid the need for a load equalizer.
Personally, I'm quite happy to not have a load equalizer on the bike while using serveral LED lighting products (BAL tail light, custom tri-bar LED light with resistors installed, etc.)
Good luck with your research.
Carl
Carl
I just ordered the 02d2 resistor with their integrated tail light turn signal. will I have an issue? This is for my Dyna. Will this be able to be used with teh run turn brake module?
Light
http://www.d2moto.com/p-8621-harley-...t-signals.aspx
Reistor
http://www.d2moto.com/p-7074-1-motor...-resistor.aspx
Light
Reistor
The best product, hands down is the Badlands Illuminator. It's a run/turn/brake controller that doesn't overheat no matter how many L.E.D.'s you run. It has a built in load equalizer and is alarm compatable and it's plug & play.
http://www.badlandsmotorcycleproduct...cts/BETCSM.htm
If you're having a problem, call CD. Their customer service department is awesome.
Nope. After install, the instructions said to activate the right blinker for 3 blinks, then the left for three, then the right. That sets the TSSM up to work with the load equalizer. No issues at all.
