Are these the part #'s for the inner and outer cam tensioners on an 88 cube motor, 39964-99a secondary and 39954-99a primary. Any help would be appriciated. I have 29,000 on the old girl, going to throw a cam in her and change tensioners , lifters and bearings while i'm at it. Wanting to place an order at Zanottis. Found the numbers using the search but mentioned something about new style and old.
just my 2 cents but if your going to spend the money on the new cams, bearings and tensioners Id probably go ahead and upgrade to the hydraulic tensioners. Thats what I just did and its worth it.
While i'm in their the inner bearings are going to get changed. As far as going with the new style cam plate, I just don't want the added cost. Ordered new tensioners from Zanottis and going to put them in whether they need it or not. Thank fellows.
