Bright Ass Lights/Turn Signal Module Question
Has anyone who has done the turn signal module modification on their FLHT had issues with their BAL lights? I would especially be interested if you've also done this modifiaction with your tour pak lights. I have an '09 that I'm thinking of adding the BAL lights. Thanks.
I have the HD rear turn signal module that causes them to operate as run and brake lights; and, HD's tour pak turn signal conversion kit that causes the rear run/brake lights on the Ultra tour pak to function as turn signals.
Everything works fine with the BAL-1R on my bike.
Carl
You should probably specify which modules you are using: HD, Custom Dynamics, etc. and for which application; e.g. rear turn signals functioning as run/brake lighting; side marker lights on tour pak funcitoning as turn signals/brake lights; etc.
Carl
Carl
![Icon That](https://www.hdforums.com/forum/images/smilies/icon_that.gif)
Captainjack,
I have no idea--literally no idea and I wouldn't give an opinion since I've see posts about problems with load equalizers/LED's etc. which I have never understood or researched; and I've never used load equalizers or expensive LED's. I have inexpensive LED's in the rear turn signals that I purchased years ago and everything works fine.
Carl
Carl
