Long term storage
These items come to mind for long term storage:
Run fuel stablizer through the system, drain the tank.
Climate controlled storage.
Remove the battery from the bike. Trickle charge should be checked once a week so its not a good idea to leave it unattended. You can charge the battery when you get back.
Bike Cover.
Above all else, be safe.
Bike Cover.
Here's a good read on gas. Looks like I was wrong about draining the tank as a previous poster stated as doing so can cause rust and other issues.
http://autos.aol.com/article/does-gas-go-bad/
Received 28,332 Likes
If you don't have anyone to check on your battery tender atleast weekly,
I'd pull the battery and store it in a warm dry area....and not on concrete.
Add some variety of a gas stabilizer. I also put 2" of styrofoam insulation
under each wheel and a 2" block of wood under my 'jiffy stand' too offset the
2" the wheels are elevated.
Drape a king-sized bed sheet over her and walk away....
