tri bar install...help please
If your turn signal bar has the license plate light built-in, you have a tri-bar light intended for use on an EG or other bike with a fender tip light or RGU. When the fender tip light is removed to install the tri-bar light, the chamber is available for the tri-bar light connector.
On SG's with a tail light, the circuit board's upper left chamber is used for the license plate LED's in the turn signal bar, and the tri-bar light is connected to the bike's tour pak wiring harness.
Chances are you can exchange the LED for the correct one, i.e. the run/brake version for SG which will have the correct connector on the end of the harness for connecting to the tour pak harness connector.
If you want to keep what you have, you'll need to splice the license plate and tri-bar lights so the two lights can share the same connector plugged into the upper left chamber.
Carl
Carl
I reponded to your PMs but I wanted to post here in case someone reads this and has some better intel on this.
First, I believe there is an unused loom on your bike somewhere under the left side cover. It is the loom that would go to a tourpak if you had one. This look has all the wires you need to install the tribar light. I'm guessing on this because all I know is what I've read in some other threads. My bike has a TP so that loom is being used.
Second, if you can't find that loom, I would recommend that you tap into the wiring under your taillight. I tapped into the wires going to my ACC switch for my Kury Driving lights. It looks clean and will last forever. I soldered them and used shrink tubing on mine. None of those funky connectors that work loose.
Hope you get some feedback on the loom. That would be the best way to solve this. Otherwise, get out your soldering iron, shrink tubing, and heat gun.
Steve
army_sarge
03-22-2010 02:15 PM
UltraKla$$ic
04-25-2008 10:41 PM
