Help with carb removal
I can't figure out how to get the throttle cables off my carb to I can remove it. There is a cable coming down that wraps around a wheel and feeds back up. Then a second cable that connects to the side with a plastic rotating gromet. How do I get these off?
I have the choke, vacuum and fuel lines disconnected and the carb is broke away from the manifold. Just need to get the throttle cables off. Thanks.
You have to loosen the cables up by the trottle. There is usually a rubber boot on the cables right after they come out of the hand control, slide the boots off, loosen the lock nut and break the cables down, (screw them all the way together) that will give enough slack to get them off the carb
...what Harley Tuner said...plus...at the ends of these cables are little tiny barrel shaped end-nubs for lack of a better word. These end-nubs fit into a little slot. When you loosen up the cables so there is lots of slack in them, you can manipulate the cables to get the barrel end out of the slot, that's how you free them up. By the way, these end-nubs are on both ends of the cable, and the same method applies if you were swapping out the throttle grip too.
