ROADGEARŽ Hi-Tec Digital Tire Gauge
I have a question to those who have this tire pressure gauge.
http://www.roadgear.com/Accessories/...al_Tire_Gauge/
I have a cop bike with the same rims as a Street Glide. Checking the tire pressure is a real PITA. If you have this gauge does it make it easier to check the tire pressure? How accurate is it? I probably lose 2 to 3 pounds of air pressure every time I check my tires. It gets to the point I just don't want to check them. But, I do anyways. Real frustrated.
Thanks and ride safe,
Bob.
Bob.
Not sure about that gage but what I do is connect a "Chek-a-spare" hose to the valve stem then check my pressure. A little extra time but on my 09 Utra's wheels this sure makes it easier.
http://www.getagauge.com/accessories.cfm
Ride safe,
Bob.
Also look into this one: Accutire MS-4710B Motorcycle Tire Gauge
It's half the price of the Roadgear and has slightly better reviews on Amazon.
Unfortunately I can't comment on the accuracy of either gauge, but I am interested in something like this as well.
I read a positive review by Web Bike World on the Roadgear. http://www.webbikeworld.com/r2/rg/air/air.htm But I wanted to hear "real world" results.
Bob.
I have been considering a tyre monitoring system. We have a new car with it on and it tells you when a tyre drops pressure below a pre-set level. Doesn't say which wheel it is, but puts off checking pressures until necessary. It also helps that by warning of a tyre pressure dropping, a puncture can be identified before it becomes a real problem.
There are after-market bike systems available and it has come up here on HDF in the past. So that is an alternative way of putting off the dreaded pressure check!
