ROADGEARŽ Hi-Tec Digital Tire Gauge
I use the TPMS on my bike now. As previously stated you loose 2 or 3 lbs of air everytime you check your tires, not to mention you have to be a contorsionist and have hands the size of a squirrel's to actually get the gauge on the tire valve. This way I can see my tire pressure anytime and if there is a leak it will alarm me. Kind of on the expensive side but very convenient.
I have been considering a tyre monitoring system. We have a new car with it on and it tells you when a tyre drops pressure below a pre-set level. Doesn't say which wheel it is, but puts off checking pressures until necessary. It also helps that by warning of a tyre pressure dropping, a puncture can be identified before it becomes a real problem.
There are after-market bike systems available and it has come up here on HDF in the past. So that is an alternative way of putting off the dreaded pressure check!
Thanks for all the feedback. With everyone's help I'll make a decision and post my opinion of the product(s).
Ride safe,
Bob.
Agree that checking the tire pressures is a PITA especially the rear tire.
Have the HD tire gauge
But still checking the pressure and adding air to the rear tire was a pain.
After looking at options here on the forum I ordered a EZ-Air gauge off Ebay for $20.00 shipped.
Makes quite a difference. Just hook it to the valve stem and you can check the pressure then add air very easily. Also with the pressure release button makes it great for if too much air is added.
Forgot to mention Made in the good ol USA with a Lifetime manufacturer warranty.
I bought that identical tire gauge, with a different name stamped on it, in a discount bin at the local auto parts store for $10. I suspect it is one of those things made in a factory in China someplace and different vendors just print their name on it. Works well and seems fairly accurate. For about $25 you should be able to find a 12v tire pump with built in digital gauge.
I have a question to those who have this tire pressure gauge.
http://www.roadgear.com/Accessories/...al_Tire_Gauge/
I have a cop bike with the same rims as a Street Glide. Checking the tire pressure is a real PITA. If you have this gauge does it make it easier to check the tire pressure? How accurate is it? I probably lose 2 to 3 pounds of air pressure every time I check my tires. It gets to the point I just don't want to check them. But, I do anyways. Real frustrated.
Thanks and ride safe,
Bob.
Bob.
here's a little something I made up for the valve stem issue
The gauge comes with a different chuck that won't work at all with the spoke wheels so I cut it off and installed this 'right angle' chuck. Had to grind down the sides a bit to make it fir around the spokes but sure makes adding and releasing air a whole lot easier.
